IndoDarknight Building a RaceCar
Re: IndoDarknight Building a RaceCar
by Bigwilly » January 14th, 2016
You mentioned you had TL-S calipers on your i4 accord. Did those bolt right up without modification or any brackets? Would they work for the 6-6? And we're they worth it?
by indodarknight » January 14th, 2016
ChrisB8thgen wrote:what were the specs on the black ce28s?
18x9.5 +35 all around
Bigwilly wrote:You mentioned you had TL-S calipers on your i4 accord. Did those bolt right up without modification or any brackets? Would they work for the 6-6? And we're they worth it?
yeah, 05 brembo caliper from tl-s, will fit both v6 and i4, you will need to drill on the bracket due to the bolt being slightly bigger, and you will need the pads for that caliper, and s2000 rotors other than, it functions beautifully!
by Bigwilly » January 19th, 2016
ok cool thanks for the info Indo! how did that setup perform for you?
by indodarknight » January 26th, 2016
Bigwilly wrote:ok cool thanks for the info Indo! how did that setup perform for you?
I actually like it, if you put 15mm spacers on the rear
I think i want to go back to 18" still debating... 18" are lighter and cheaper on tires too, hahahaha
finally updated after all these years :D
^ with the one and only Bryan ;)
I love the look of the RL caliper on the new wheels... and back to 18" here we go! #teamvolk
Users browsing this forum: No registered users and 49 guests
