jman64cola’s 08 accord ex-l coupe project over engineered
Jonkassidy
Re: jman64cola’s 08 accord ex-l coupe project over engineered
by Jonkassidy » April 29th, 2015
The wood floor looks so nice!!! Can you elaborate a little more on building it?
by jman64cola » April 30th, 2015
Once I get some time I will write up a how to, but basically you build a frame, trace your trunk out with foam board (dollar stores stuff works great) then you transfer that to your base board. Then once all that is cut out you start piecing in the floor 1 piece at a time. I did it all out side of the trunk then would test fit a few sections at a time.
No more need for the hood prop
Jonkassidy
by Jonkassidy » April 30th, 2015
jman64cola wrote:Once I get some time I will write up a how to, but basically you build a frame, trace your trunk out with foam board (dollar stores stuff works great) then you transfer that to your base board. Then once all that is cut out you start piecing in the floor 1 piece at a time. I did it all out side of the trunk then would test fit a few sections at a time.
Thanks bud,I'll be looking for that write up.
by jman64cola » May 4th, 2015
Took best of show 2 weeks ago at the rock island car show.
Went to the jc witney car show yesterday.
Had a good time can't wait for more shows.
datkidfromTO
Re: jman64cola’s 08 accord ex-l coupe project "over engineered"
by datkidfromTO » May 5th, 2015
jman64cola wrote:
Also got my pads and rotors in. Look great and will be installing in the next few weeks once I get my jack stands back.
How did you like the Max brakes? I'm planning on getting them for my car.
IG: @datkidfromTO
2008 Accord Sedan i4 EX-L w/ Nav
by jman64cola » May 6th, 2015
I like them they are performing well, but I'm not sold.on the pads yet, I'm thinking about swapping them out to something else. I'm getting a good bit of brakedust. Might go with some oem cerimanc pads or ebc pads but the rotors were well worth the money.
datkidfromTO
by datkidfromTO » May 6th, 2015
jman64cola wrote:I like them they are performing well, but I'm not sold.on the pads yet, I'm thinking about swapping them out to something else. I'm getting a good bit of brakedust. Might go with some oem cerimanc pads or ebc pads but the rotors were well worth the money.
Thats good to hear! The company is local here in Toronto so I'll try to pick them up from their warehouse.
IG: @datkidfromTO
ChrisB8thgen
by ChrisB8thgen » May 17th, 2015
How did you install the front lip? just drill into the bumper and just secure a nut onto the other end?
2011 Honda Accord Coupe LX-S
by jman64cola » May 18th, 2015
use the supplied screws and just install them into the bumper and lip. no need to drill since they make there own holes.
