Cool Tools
korrupt3dazn
Cool Tools
by korrupt3dazn » November 18th, 2014
Just seeing if there are any cool tool you guys use.
So far one of my favorite is the Irwin bolt Extractor set. It lets you remove rounded off bolt heads. Saved me a couple times.
I found with these its best not to use impact gun it will cause the extractor's teeth to strip. Also when you place it on the bolt head use a hammer and tap it into place until
it firmly grabs and you aren't able to spin it by hand.
Irwin 394001 (Starter Set) http://www.amazon.com/Irwin-Industrial- ... +bolt+grip
Irwin 394002 (Expansion Set) http://www.amazon.com/Irwin-Industrial- ... +bolt+grip
Here is a picture of 2 bolts I removed off my buddy's Evo X exhaust. The bolt were rusted in place and the head got rounded off. I made it worse trying to use vise grips.
Re: Cool Tools
by Brian » November 18th, 2014
I need this! I stripped a nut on my spacers and I can't remove it so I'm rubbing on every turn and dip.
korrupt3dazn
Re: Cool Tools
by korrupt3dazn » November 23rd, 2014
Here is another tool that saved me.
While installing my Jpipe I replaced my studs on the pre cats. The problem was I cross threaded that stud and then to top it off I cross threaded the nut onto that stud. I was able to tighten it all the way and run with it for a while. I wanted to go back to stock and I knew I had figure out how to get it all off. I used a dremel and was able to get the nut off but the problem was the stud. I tried using Vise grips but all it did was rounded the stud even more making it next to impossible to grip it. Looked on youtube and found a video on demonstrating this tool. Ordered it and was able to get the stud out in the first shot.
Titan Stud Puller 3/8 - http://www.amazon.com/Titan-Stud-Puller ... Titan+stud
Picture of the took with the stud.
Close of picture of the stud inside the tool
Picture of the stud itself
Here is a video on how it works
amanda2519
Re: Cool Tools
by amanda2519 » December 18th, 2014
They're not technically "tools" but I found an LED light that's great for working on cars: http://www.amazon.com/Risk-Racing-00-11 ... racing+led
And some sweet bungees: http://www.amazon.com/gp/product/B001P9 ... UTF8&psc=1
@amanda2519
korrupt3dazn
Re: Cool Tools
by korrupt3dazn » January 12th, 2015
I use to hate taking the bumper clips out because they either always break or part of the middle clip breaks, etc...
I used this tool and pops it off so freaking fast and with no effort. You can buy this at harbor freight.
Push Pin Pliers
http://www.harborfreight.com/push-pin-pliers-67400.html
This is used to remove these clips
I use to hate taking these clips out because they either always break or part of the middle clip breaks, etc...
Re: Cool Tools
by staro0989 » January 12th, 2015
This should be handy for anyone crimping 1/0 wire:
I am in the process of rebuilding my stereo system and I think this solution is much better than hammering the terminal directly.
