jman64cola’s 08 accord ex-l coupe project over engineered
Re: jman64cola’s 08 accord ex-l coupe project over engineered
by jman64cola » October 30th, 2015
I used the controller from the retrofit source. Only one you can use with there halos
by jman64cola » November 11th, 2015
Picked this up for the accord recently.
Also working with Honda on the oil consumption issues. Will update once I hear back for sure.
by jman64cola » December 15th, 2015
So my car is going into the shop Friday for the rebuild of the motor. Honda is covering the cost of it all.
Also have some plans in the works for it once I get it back, plastics have all been pulled off for my future plans. Stay tuned for a big change.
by jman64cola » December 19th, 2015
Well the accord is officially in the shop now. I'll be picking it up after the new years since I'll be out of the state.
by jman64cola » January 7th, 2016
Picked the accord up. Everything feels good and looks right, time will tell if everything is fixed.
On a side note it looks like something backed into and scraped my rear bumper at the shop, I will be going back today to see what they are going to do to fix it. Image
by coolblue » January 11th, 2016
I hope they will fix it for you bro...
almost158
by almost158 » January 12th, 2016
Hope Everything Goes well. I actually just got mine back from the dealer for the oil consumption issue as well. I have about 500 miles on it since and it feels really good, i have been babying it still though because i want everything to wear in properly. Still haven't checked the oil yet but will do that soon.
Now When you say rebuild the motor what all did they do on yours? I talked with the tech fairly often and I guess they just replaced the piston rings. I hope they would check the clearances on each cylinder as well but not sure if they do that, or if the rings they put on are any different than the originals.
Thanks
Re: RE: Re: jman64cola’s 08 accord ex-l coupe project over engineered
by jman64cola » January 12th, 2016
almost158 wrote:Hope Everything Goes well. I actually just got mine back from the dealer for the oil consumption issue as well. I have about 500 miles on it since and it feels really good, i have been babying it still though because i want everything to wear in properly. Still haven't checked the oil yet but will do that soon.
Thanks
From what I was told and what I've read they do new pistons, rings, and cylinder walls if it needs it. They also do new head bolts and all the gaskets related. And there also are a few odds and ends parts. And yes they size and gap the Pistons properly. that's why mine took so long so they could get the right size pistons in.
Talked it over with the dealership. They are going to strip the bumper, fix the scratches and repaint it all.
by jman64cola » January 22nd, 2016
Got my car back from the dealership. The bumper has been fixed and painted. It looks great. Now it's time for me to finally start my winter build.
It is currently May 22nd, 2024
