Tools for a Retrofit
by milmast » January 21st, 2015
My main question is what things do you need to open up the headlights assembly and then reseal it so no water and condensation get inside the housing? I've never done a retro or even opened up the housing for that matter. Any help and insight would be appreciated. Thanks guys!!
Re: Tools for a Retrofit
by jman64cola » January 21st, 2015
I opened mine up with a heat gun and screwdrivers and it wasn't the easyest thing to do. I'm going to bake them to put them back together. I'll let you know how it turns out
by mcbtay » January 21st, 2015
I used an oven to open my headlights. Around 350 degrees for 8 minutes or so. Screwedrivers will help, but when the housing is hot from being in the oven or under a heat gun, it's really easy to bend and distort the housing. As far as resealing, the process is similar. I took the butyl tape from TRS and lined the housing with it, popped it in the oven to soften the glue, and then pressed them together. C-clamps will also help.
by milmast » January 22nd, 2015
What did you use to reseal it? Thats my main concern
by teezythakidd » January 23rd, 2015
milmast wrote:What did you use to reseal it? Thats my main concern
rubber glue, bro! right from TRS –> http://www.theretrofitsource.com/access ... -glue.html
