v6 UR stock diameter lightweight pulley install question
lebanesebeast
by lebanesebeast » January 26th, 2015
I will be using an air wrench to get the stock one off but when installing the UR pulley how exactly should i go about tightening it and to what degree? And if a torque wrench is required how much should i torque it too
2012 v6 sedan
Takeda SRI, zdx intake manifold, zdx throttle body, RV6 HFPC, ATLP V2 j pipe, 3rd cat delete, 2.5" custom obx catback
Re: v6 UR stock diameter lightweight pulley install question
by @ccord10 » January 27th, 2015
it technically should be torqued to spec but since it hard to hold the crank without special tools you can use an air gun if your careful. i usually give them 2 quick trigger (1/2 second) pulls to tighten them after the bolt is snugged up.
lebanesebeast
by lebanesebeast » January 28th, 2015
@ccord10 wrote:it technically should be torqued to spec but since it hard to hold the crank without special tools you can use an air gun if your careful. i usually give them 2 quick trigger (1/2 second) pulls to tighten them after the bolt is snugged up.
Got it, btw what is the amount it should be torqued to? Thanks
2012 v6 sedan
by @ccord10 » January 28th, 2015
torque for the crank pulley is 47ft/lbs.
lebanesebeast
by lebanesebeast » January 29th, 2015
@ccord10 wrote:torque for the crank pulley is 47ft/lbs.
Alright cool, thanks!!
2012 v6 sedan
