Will those wheels fit? START HERE..
Itz_duhnes
by Itz_duhnes » November 6th, 2014
Want to know:
- Do these wheels fit?
- Will it rub?
- What size and widths should I buy?
- Sedan and Coupe fitments?
START HERE.
This will help eliminate individual post about wheel fitment. Please start your search here before creating another thread.
- itz_duhnes
Build what makes you happy
My Build Thread
authenicc
Re: Will those wheels fit? START HERE..
by authenicc » November 7th, 2014
Lookin at grabbin a pair of vossens for my black sedan i was considering a 20x8.5 +30 for the front and 20x10 +30 for rear with a 245/35/20 tire size had some noname 20s on before rubber in front no idea wt the offset was.. but it was wide currently lowered on Tein coils any recommendation on wt i should run interested in 20s only..
Inspire_cp3
@Authenicc
I'm rolling with Rohana RC10's 20x10 +30 all around and wrapped with 235/30/20 Lexani's
Originally Posted by takezo
you mean Neal Foose!
authenicc
@inspire_cp3 any pics? hows the front doin? any rubbing/ rolled fenders? assuming your lowered ? thanks for the reply btw
Inspire_cp3
On my ride, the fenders are rolled but when busting a bitch, they rub nasty.
On the wifey's her's are rolled but not necessary. We just got them rolled just in
case she needs to follow me when we go in n' out of traffic on the freeway
authenicc
preciate it! clean set up
NOEL_F13
Recently just purchased a set of wheels 20x10.5 +25 front and 20x10.5 +5 rear. I knew I could pull off the fronts since I know a few people running the same setup but I was unsure of what I was going to need to do for the rears, so I did some research of other cars and got a good idea of what I wanted. After receiving the wheels I test fitted the wheels with the natural camber of the car being lowered and to my huge surprise they tucked by about a credit card amount of space to spare. Mind you my fenders have been rolled and pulled but from just the natural camber of me being so low there was about -7 degrees of camber. I still had the camber kit put on the car but the specs stayed about the same. My current suspension setup is Bc coilovers with the extreme low option and they were just about maxed out in the rear. So to give you an idea of being slammed and the natural camber you can fit a 20x10.5 +5 with a roll and minor pull.
IG@Noel_F13
by Bigwilly » January 18th, 2015
Noel your setup is dirty! Are you rolled up front? And are you running front and rear camber? Or just rear?
NOEL_F13
by NOEL_F13 » January 18th, 2015
Thanks. Rolled and pulled up front. Still rub like crazy when turning. No camber kit up front
IG@Noel_F13
by Bigwilly » January 19th, 2015
Cool thanks for getting back. Don't think I will go that aggressive but it helps give me an idea for offsets
