Front Upper Adjustable Ball Joints?? Hitting????
Jessikat22
by Jessikat22 » March 31st, 2015
Hi there.
Just got done installing some front upper adjustable ball joint, did the alignment and it is perfect.
The nut on the ball joint is hitting the frame when going over bumps a bit hard.
NOTE: I'm pretty low.
Have you guys had this problem too and what have you done to fix it? I was thinking on grinding down the nut a bit and using the air hammer in the area where it hits to make an indentation to make room for travel?
Please let me know. Thanks.
Re: FRONT UPPER ADJUSTABLE BALL JOINTS?? HITTING????
by mcbtay » April 1st, 2015
No need for all caps. Please don't do this in the future. I've updated your post to not be all caps.
This is a known issue with the upper adjustable ball joints. Did you get just the joints and put them into your factory control arms? Or did you get some of the newer control arms that come with the adjustable ball joints pre-installed? For the joints that you just press into your factory control arms, those are known to hit the strut tower metal... Only way to resolve it is to notch (cut a hole) in your engine bay to accommodate the ball joint. Definitely would not recommend grinding the nut on the ball joint itself.
Users browsing this forum: No registered users and 62 guests
