09+ TL SH-AWD Rear Sway Bar (20mm)
1 x 52300-TK5-A02 - Acura SPRING, RR. STABILIZER
2 x 52306-TK5-A01 - Acura BUSH, RR. STABILIZER HOLDER
Bushing brackets are exactly the same. Make sure to lube the bushings when putting this new sway bar in. I have an SE model so it made a huge difference going from a 13mm bar to a 20mm bar. When I did it was around $90 shipped for everything listed above but I believe it's since gone up. Great bang for buck upgrade though!
Re: TSX Rear Sway Bar (20mm)
by staro0989 » November 7th, 2014
mcbtay wrote:1 x 52300-TK5-A02 - Acura SPRING, RR. STABILIZER
If it is a 20mm bar, then it is the 09+ TL SH-AWD rsb. The 09+ TSX rsb is 17mm and the 09+ TL non SH-AWD is 19mm. There is also a 24mm and 25.4mm from the TLX but they will not fit due to our very miniscule clearance to our subframe with the 20mm rsb. Aftermarket rsbs that are larger than 20mm actually have a bump out to compensate for this similar to how our factory rsb was designed.
staro0989 wrote:If it is a 20mm bar, then it is the 09+ TL SH-AWD rsb. The 09+ TSX rsb is 17mm and the 09+ TL non SH-AWD is 19mm. There is also a 24mm and 25.4mm from the TLX but they will not fit due to our very miniscule clearance to our subframe with the 20mm rsb. Aftermarket rsbs that are larger than 20mm actually have a bump out to compensate for this similar to how our factory rsb was designed.
Thanks for the correction! I knew something seemed fishy when I was typing this up last night. It's been a while since I did this mod haha.
Users browsing this forum: No registered users and 0 guests
It is currently May 31st, 2026
