work emotion D9r
GODZILLA
work emotion D9r
by GODZILLA » June 5th, 2015
Hi
Im planning on ordering some work d9r wheels and a TEIN street advance coilovers
http://www.work-wheels.co.jp/products/w ... tem_id=166
for my daily 2010 accord coupe and want to check with you experienced guys if Im on the right track
specs:
F: 19x9.5 +38 245/40
R 10x10.5 +30 255/40 or 245/40 <-- not sure till now need help which is better ... the 245 seemed to have the same overall Circumference as the front but more poke than the 255 which seemed to have about 10mm nore Circumference than the fronts
so is it going to need work like a fender roll or pull front or rear since im going to lower it 1.5in intially and go lower step be step from there
and are these tire specs too stretched for a daily since is my main concern is that the lip doest hit the Raised pavement markers between the lanes since there are lots of them where I live
thanks, :D
GODZILLA
Re: work emotion D9r
by GODZILLA » July 16th, 2015
wow ... its been 6 weeks with no replies ... lol
so, anyway I placed the order and the weels will take about 6 weeks to be manufactured
the coilovers are in stock but will be shipped 4 weeks late due to the fact that I ordered godspeed camber, toe and traction arms and these have an ETA of 3 weeks
I think I need to start a build thread ... hmm
by mcbtay » July 17th, 2015
Yes, start a build thread! I don't think your specs are super duper aggressive, so you should be able to get away with a fender roll. However, I'm a sedan owner so coupe guys would know best.
What kind of coilovers did you order?
by Bigwilly » July 19th, 2015
I'm running very similar specs with just a fender roll. 20x9.5 +38 245/30/20 up front 20x10 +30 255/30/20 rears, lowered about 2.5" on BC coils. Sits nice and flush, you'll be fine
Richard
by Richard » October 18th, 2015
Yeah if im not mistaken it seems you coupe guys have a lot more room for an aggressive setup compared to a sedans. Im trying to run 19x10 et24 in the rear and dang is that pushing it
Sent from my LG-H811 using Tapatalk
GODZILLA
by GODZILLA » July 1st, 2016
well...
its been a while since I started this thread
I ended up not buying the wheels but got the tein street advance coilovers and the the jspeed 3 arm kit
shoud I start a build thread ... hmmm
by coolblue » July 8th, 2016
Just start the build thread lol...
