BBK Compilation
BBK Compilation
by Big LrG » September 30th, 2015
Lets see your pics of your BBK setups!
Post info about any additional parts required, wheel specs, spacers, or what wheels didn't clear you specific setup!
Stoptech Wheel Fitment Guide: http://www.stoptech.com/docs/wheel-fitment-templates/98-436-2430-02_FP
This "should*" work with majority of the different calipers on the market.
***using should loosely. I am not to blame if it does not work. Please check with your desired manufacture (if not Stoptech) on their caliper overall sizes and dimensions.
Kit or Parts Sourced: Stoptech Trophy BBK
Sourced - What parts are requireed?
Total Cost: $4k :lol: ?????
Wheels: Fits Enkei PFO1 18x9 +35
Will Not Fit Enkei RPF1 18x9 +35 (spacer required)
Hayydeen
Re: BBK Compilation
by Hayydeen » September 30th, 2015
Re: BBK Compilation
by staro0989 » October 1st, 2015
Kit or Parts Sourced: XLR8 Touring BBK by Stoptech
Total Cost: $1.2k
Wheels: Fits Acura TSX A-Spec Wheels 18x7.5 +55 w/ 15mm spacer
Re: BBK Compilation
by Big LrG » October 2nd, 2015
staro0989 wrote:Kit or Parts Sourced: XLR8 Touring BBK by Stoptech
Total Cost: $1.2k
Nice to see another Stoptech Kit out here!
jonathane
Re: BBK Compilation
by jonathane » October 3rd, 2015
Kit or Parts Sourced: 2005 - 2012 Acura RL BBK
Sourced - What parts are required?
2006 - 2012 Nissan Maxim Rotors (could probably use 2004 - 2005 rotors as well)
(EBC USR Brake Rotors Part#7218USR [for 2004 - 2005 Part#7220USR])
2005 - 2012 Acura RL Brake Pads
(EBC Green Stuff 2000 Series Part#DP21735) [you'll get squeal even after break in]
OR
(EBC Ultimax2 Part#UD1091) [haven't tried these yet]
2008 - 2012 FastBrakes Acura RL Caliper Adapter Kit
2008 - 2012 Goodridge SS Brake Lines (Part#20007)
3mm or 5mm Spacers
Total Cost: $1,600
Wheels:
Will Fit: Honda 18" Rims (will still need 3 - 5mm spacers)
Will Not: Unsure if 17" Rims will fit or not, not taking the chance to damage the powder coat
Re: BBK Compilation
by Big LrG » January 19th, 2016
Bump! Some good info for the guys looking for the RL Setup!
Re: BBK Compilation
by Bigwilly » January 31st, 2016
anyone have a firm answer as to whether or not the RL BBK will clear the OEM 18s? I am looking at getting a RL kit and have 20" summer rims that will clear no problem but i usually through my 18s on for the winter and I'm wondering if i will run into any fitment issues.
Re: BBK Compilation
by Big LrG » February 23rd, 2016
Bigwilly wrote:anyone have a firm answer as to whether or not the RL BBK will clear the OEM 18s? I am looking at getting a RL kit and have 20" summer rims that will clear no problem but i usually through my 18s on for the winter and I'm wondering if i will run into any fitment issues.
@jonathane say's they will fit but need a 3-5mm spacer in the post above.
Re: BBK Compilation
by Bigwilly » March 24th, 2016
thanks for this!
kevtheo1191
Re: BBK Compilation
by kevtheo1191 » March 25th, 2016
thanks for this!
For the stock wheels 18x8 +55 you will need at minimum a 15mm spacer. I have a 20mm and it clears no problem, but that is what I already had.
It is currently March 31st, 2026
