New purchase - troubleshooting
Firefaux
by Firefaux » February 3rd, 2020
Recently picked up a V6 Hybrid from the auction. It’s a 2007 with 270k miles so it’s been around. The engine bay looks unmodified but relatively well maintained. It has an old battery, cracked intake hose, and doesn’t start. It cranks over stalls then dies.
I suspected the fuel pump at first but after replacing it and the intake hose, fresh battery, still no go. No difference when IMA is off/on.
I’m going to test the fuel pressure and check spark next. The only OBDII code is a P1445 but this should prevent it from running.
Thanks for any input you guys may have in advance.
It is currently May 31st, 2026
