Illuminated Door Sill DIY.
This the 4 Doors Illuminated Door Sill I bought from the eBay. I like to share this MODS for the Coupe. Do it on your own risk :D
• Tools you need And the Illuminated Door Sill
• You need the remove the cover and screw before to pop the side door cover
• After to removed the door cover. Clean the area before you put the door sill. Measure where the center and place the door sill
• Removed the rubber seal. Check where's the curve and place the wire
• Now we need to check the (-) Neg wire..
• Remove the Cover and screw to check the (-) Neg color wire- It's Solid Brown @ Driver Side
• Open the black loop to find the Solid Brown for (-) Neg Wire.
• I used T Tap for connection
• Here's the Passanger Side. Need to look for (-) Neg Solid Green
• Now need to connect and find were the (+) Pos Wire. I ran the (+) Pos wire on the inside of the carpet and removed the center side cover (Passenger and Driver Side).
• I used Tap Fuse to connect on the Fuse Box (Use #14) for the (+) Pos Wire.
• The Result of the Illuminated Door Sill
• Diver Side
• Passenger Side
Re: Illuminated Door Sill DIY.
Great post! The detailed write up is perfect for anyone looking to do this mod (maybe me soon :D)
by teezythakidd » November 13th, 2014
I still get scared that I'm gonna break a clip trying to remove the door sill cover lol. This is a great write-up!!
by coolblue » November 14th, 2014
Thanks .. This mods is the easy one.
by staro0989 » November 15th, 2014
Very nice! Are these OEM sills?
by coolblue » November 15th, 2014
Nope.. I bought this on ebay.
coolblue wrote:Nope.. I bought this on ebay.
Oh okay, cool! Thanks for the info. I may get these soon.
Rashman94
by Rashman94 » January 6th, 2015
Hey man. I have this same exact eBay kit for my sedan. I installed them a year ago and after hours of trying and days of research I gave up. Do you know how I can get them to turn on when the dome light turns on? I wanted them all to turn on with it, because if I wire the front two to the doors then the backs will still be silly because there's no lights in the rear doors. I'm not sure what to tap into. Any help would be nice! I'll get back into trying after reading this, my hopes got back up haha.
Tints- 35/20%
Roof/trunk spoiler
Altezza Spyder tails
K&N typhoon SRI intake
Megan Racing Strut Bar
Ksport Kontrol Pro coilovers
18x8 A-Tech wheels/nankangs
Ktuner
StopTech rotors/pads
by coolblue » January 6th, 2015
coupe is pink wire .. Check your dome light wire and use tester which one is it , they have 3 wires one of them is for dome.
by coolblue » December 25th, 2015
Update the Photo you can see it now lol..
It is currently July 26th, 2026
